700R4 Temp Gauge
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by YardPup, May 14, 2001.
  1. YardPup
    YardPup Registered Member
    May 14, 2001
    6
    Were would the best place be to install a temp sender on a 700R4 in a 91 Blazer?
  2. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Used the Search button on temp sensor....
    <A target="_blank" HREF=http://www.coloradok5.com/forums/showflat.pl?Cat=&Board=blazer4x4&Number=134114&page=&view=&sb=&vc=1>http://www.coloradok5.com/forums/showflat.pl?Cat=&Board=blazer4x4&Number=134114&page=&view=&sb=&vc=1</A>
  3. YardPup
    May 14, 2001
    6
    I searched and didn't find much help.
  4. 4xmac
    4xmac Registered Member
    May 1, 2000
    82
    Calif. Oceanside
    Yardpup, I just tapped into one of my stainless steel braided hoses with a tee fitting which leads from mt tranny to the trans cooler and back again. Or you can have an adapter welded into the side of the tranny pan wich would except the sender. Hope this helps.
    MAC
  5. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Yeah that link I gave you was the most info in one post....
    Call tranny shops for ideas and then post the ideas here for
    feedback....? I want to do it also so am curious about the results. I'll try to make some calls and post.
  6. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    I can't remember who on the board gave me this idea, but I'm going to get a second temp sender and have one in each line. Wire them to a DPST switch (mine was like $4 from RadioShack) and now you'll know your fluid temp coming out and going in. This way, you'll know if you're overcooling or undercooling.
    [​IMG] Semper Maintenance!
  7. silverado
    silverado Registered Member
    May 8, 2001
    18
    Gander, Canada
    Yeah, please post the mechanics of the solution.
