700r4, th350, th400, sm465?
Discussion in 'The Garage' started by outlaw612, Oct 28, 2004.
  1. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Does anyone know the differences in length of these transmissions? Im tring to figure out what driveshafts to be looking for. The truck has a 465 now so what if I go to a 700r4, or to a th350, or to a th400?
    Thanks guys.
  2. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    a 400 is 4" longer than a 350
  3. outlaw612
    Feb 11, 2001
    2,342
    Any idea on how they compare to the 465?
    Thanks for the info /forums/images/graemlins/thumb.gif
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    SM 465 is 12" long. /forums/images/graemlins/thumb.gif
  5. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    I swapped a th350/np205 to a sm465/np205 and used the same driveshafts.
  6. boz42
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    i have measured those combos to be the same length also but the adapters are what makes it that way
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    My front driveshaft is awful short for me to believe that.
  8. boz42
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    no jiven' /forums/images/graemlins/peace.gif
    they are really close
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I have heard this before too.
    I know for a fact the '80s combos are longer.
    Maybe Watson will chime in here, he's the expert.
  10. boz42
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    paging docter watson, paging docter watson
    the combo i am talking about was from an '81, i have been wrong before, but i am pretty sure my mind was not playing tricks on me now. it was a 465/205 w/ fig 8 pattern & was 10 spline
    are there 2 different versions of the 465/205 combos besides adapters being round or fig 8? are the legthss different on the 10 & 32 spline models?
  11. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    My th350/np205 was stock. The SM465/np205 came from another 1st gen. The factory set it up so the crossmember and driveshafts were the same. That way either trans/ TC would go in the same place.
  12. dyeager535
    26,979
    Yes. One 465/205 adapter is 7", one is 10". I posted which is which, do *I* have to go search for it? /forums/images/graemlins/tongue.gif
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I PMed him already. /forums/images/graemlins/thumb.gif
  14. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    Thanks guys.
    My 87 had a 465/208 and I swapped in a 86 th400/208. The adapter seemed to make them the same. I used the origional cross member and drivelines withought modifications,,,
    I think the rear drive line was about 1/2 inch off. Pretty damn close though...
  15. outlaw612
    Feb 11, 2001
    2,342
    Thanks for the info guys. Thats what I was looking for. /forums/images/graemlins/thumb.gif
  16. Robert79K5
    Robert79K5 1/2 ton status
    Mar 23, 2003
    335
    Douglasville Georgia
    Yup... Im another one had a 79 TH350/205. put a 10 spline sm465 in its place and the cross member lined right up just like it still had the TH350 in it.
  17. 4x4_76
    4x4_76 1/2 ton status
    Jul 22, 2001
    628
    Ylämaa, Finland
    I may perform same swap, if I manage to get all the parts, but if not, I use a TH-700. What happens to shafts?
    edit: Found some measurements from the web... Do I need to shorten the rear shaft 3 3/4"? And lenghten the front shaft same amount?
  18. boz42
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    i don't know the measurements but u are right u will need to shorten rear, & lenghten frt. if u are doing it to a k5, & u have much lift u may need a rear cv shaft.
  19. 4x4_76
    Jul 22, 2001
    628
    Ylämaa, Finland
    No lift, stock height. Law allows only 2" of lift, so I guess I won't have any problems with rear shaft.
  20. boz42
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    if u use a 208 t/case which is the most popular t-case that comes behind a 700r4, u will need a new rear shaft. it will need a slip yoke & a cv, but due to the lack of lift u could get a stock one. /forums/images/graemlins/thumb.gif
