700r4-th350???
Discussion in 'The Garage' started by bigbadchev84, Feb 22, 2005.
  1. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    will the adaptor and transfercase from a 700r4 bolt swap out to a turbo 350? also i have a 350 with a 203, will it work?
  2. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    yes but need spacer kit and special shaft for 350 tranny any tranny shop should help you. and this will keep the dshafts same .
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yes it will bolt up and the splines are the same, BUT the length of the outputshaft is different between each transfercase.
    what do you have and what are you going to?
  4. 76R4JIMMY
    76R4JIMMY Registered Member
    Feb 17, 2005
    33
    phoenix
    I HAVE A R4/203 IN MY JIMMY. IT WORKS :k5: :hack: :grind:
  5. 76R4JIMMY
    Feb 17, 2005
    33
    phoenix
    ADVANCE ADAPTER MAKES A SHAFT THAT SHORTER . YOU CAN PICK IT UP AT 4 WHEEL SUPPLY 155$:blush:
