700r4 to 205
Discussion in 'The Garage' started by dheavychevy38, Feb 11, 2003.
  1. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    is there a place to get an adapter for a 700r4 to a np 205 instead of the 241 t-case? /forums/images/graemlins/k5.gif
  2. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    I have heard some mention an adapter that makes up for the output shaft differences between a 700 and a TH350 version of the 205, but I have yet to see where one can be purchased. The option I am aware of is changing the output shaft of your 700 and using the stock adapter from a 205/350 (I think) and bolting the 205 up that way.
  3. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
  4. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    link is correct, I ordered from those peeps and the service was top notch. Got exactly what i needed, at a good price, and received it quickly. cant ask for much more. /forums/images/graemlins/laugh.gif
    afa the adapter itself, it makes up most of the distance, but i believe you still need to trim 1/8" or so off the existing output shaft. No bid deal for a shop, both joe-schmoe wanting to do the install in his driveway, its something to be aware of before hand,
    j
  5. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I have done this VERY recently. I used the adapter offered in the link. I trimmed off the tail shaft for the 700 just up from the end of the splines. This will make sense when you see the tailshaft. I used a 205 from a TH350 with the TH350 adapter as well. Bolted right up.
    I will have pics and a write-up on my website in a couple of weeks or so.
  6. 1Blazin71
    1Blazin71 1/2 ton status
    Aug 23, 2000
    112
    Los Angeles
    Advance Adapters also makes an adapter and output shaft for the 700 that allow it to mate to a 205 that previously had a 350 in front. Other combos too.
    Part No 50-6900 for 205->700R is but not listed on their website Adavance Adapters
    but can be found in some of the PDFS burried in the site.... AA GM Catalog PDF
  7. txbartman
    Jun 1, 2001
    1,975
    Plano, TX
    That is not an adapter, but simply a special shortened output shaft for the 700 to allow direct mating to a 205 originally behind a TH350. The new shaft is only around $150. BUT... you have to basically rebuild the entire tranny to get to it. Kinda makes the overall cost a bit higher.
    The adapter I used cost $65 shipped to my door and required some trimming. Found that to be much, much cheaper, less time consuming, and easier.
  8. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    When I did mine I forgot to trim the shafts the 1/8 So when it all went together it would leak if just a little but it's still a leak. The other problem is the shafts bind up which isn't good. I ended up having to send the truck down to the tranny shop cuase my 700r went south the sametime as my 208, But at the time I didn't know it till I got the 205 in, The shop saw the problem and they ground the shafts the 1/8 for me.
    But all is good now.
    Eric
  9. Chris_T
    Chris_T 1/2 ton status
    Mar 17, 2001
    718
    Saskatoon, SK
    Mine has the AA output shaft and everything went in and works perfect
