700r4 to 400 swap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by westtexask5, Dec 10, 2004.
  1. westtexask5
    westtexask5 Registered Member
    Sep 25, 2004
    56
    lubbock,texas
    i need a parts list to complete the swap. I have a 400 trans and 205 transfer case with the right extention housing but what else do i need such as shifter, linkages and such. thanks for the info
  2. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    u will need the correct adapter & output shaft for the t-400. your tranny shifter should work, u will just not line up w/ what the dash says, u will need the t-case shifter & linkage, a torque converter, & possibly new d-shafts. if u want a kickdown u will have to mount a switch under the gas pedal & run some wires for it.:D
