700r4 to a 350 trans
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RATAH, Sep 20, 2002.
  1. RATAH
    RATAH 1/2 ton status
    Aug 10, 2002
    576
    Franklin,Ohio
    Hello all
    1985 K5 Blazer
    350 with ellderbroch intake,4 barrel,
    quatdrajet,flowteck headers
    im gonna swap the 700r4 trans 208 case
    to a 350 trans 205 case
    any info you can give me
    such as drive shafts
    cross meber, linkage,vacum ect,
    also what should the converter stall be it has a 3000rpm stall im sure thats to much for my stock 350
    Thankyou all for any help and info
  2. RATAH
    Aug 10, 2002
    576
    Franklin,Ohio
    Please help me
  3. K-5 Guy
    K-5 Guy Registered Member
    Aug 7, 2002
    11
    Michigan
  4. lax037
    lax037 Registered Member
    May 29, 2001
    49
    Long Island
    To bad you're in Ohio, I have a th350 all set up with this setup. And I did use it briefly to replace my blown 700 and it was easy. Pull out your 700, put the 350 in and everything bolts right back in. All you have to do is run a vacum line to the tranny, which is easy enough.
    Hope this helps
  5. RATAH
    Aug 10, 2002
    576
    Franklin,Ohio
    Thanks all
    Lax did you have to have your drive shafts modified?
  6. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    The Tcase and Xmember stays in the stock place so the shafts dont need to be changed. I have that set up on mine. What it is is a new rear output shaft and a spacer to go between the trans and case adapter. Basicly all it does is takes up the extra lenght of the 700 that the 350 doesnt have.
  7. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    Why would you want to swap out the 700r4,the 208 for the205 I can understand, I have an 85 also and if you rebuild the 700 right it can handle over 400 hp. Very soon I will have a 406 SB with 425ft-lb's of tourque. A corvette servo and a better cooler will be enough for my 700.they are a great daily driver tranny. You don't need a stall converter unless you are running a cam with more than 224 degrees of duration.
  8. RATAH
    Aug 10, 2002
    576
    Franklin,Ohio
    im getting a deal on the trans and 205 case,
    the guy that built it built's
    alohilic motors
    and trans for em for mud bogging
    he says the 700r4 sucks
    i believe him as ive been tru 2 of em in 3 months,
    the stall on the converter is just his standered setup,
    il get 1 lower or add a cam,
    what stall do u recommended?
    Thanks guys
  9. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    If your getting a 205 case toss the 208 in the parts pile and forget it! Youll have to get new shafts made but that will prob even out to getting the swap kit.
    As far as the stall goes, maybe step it up (above stock) to a 15-1800 stall but 3000 is WAY too much for a stock motor.
  10. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    sounds like you need to talk to 73k5kid , he wants to do the exact opposite. He has a post on here that is titled, New toy questions. He wants to go from th350 to 700r4.
    John
  11. chevyracing
    Sep 8, 2001
    2,589
    Colorado
  12. RATAH
    Aug 10, 2002
    576
    Franklin,Ohio
    thanks guys
    il be doing the swap in the next few days
    and il keep you posted
  13. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    I'm planning on doing the reverse swap that you are going from t350 to 700r4 to gain the overdrive. I have already did the Ring and pinion in the rear end to 4:56 because that was what all the books said it should be with 35's. wish you were near here so I could get your old stuff, but Good luck!
