700r4 to a tb350
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cinchjeancowboy, Dec 8, 2003.
  1. cinchjeancowboy
    cinchjeancowboy Registered Member
    Dec 7, 2003
    10
    North East Texas
    How hard is this to do. My buddy said it was pretty easy. Said that you can buy a kit for about a $150 bucks it the 350 bolts up just fine. I am sick of this 700r4 and the $700 bucks to get a new one plus my labor. /forums/images/graemlins/1zhelp.gif If I go the 350 way it will save me about 300 bucks. And I know I will lose overdrive
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I am getting ready to do this swap too. Advance Adaptors sell's the adaptor and output shaft for around $200 I believe to keep your 208/241. You need the new longer output shaft for the tranny.I just bought a TH350 that had a 208 so mine is just a direct bolt up. I'm not sure on driveshaft issues yet, but I am pretty sure they will be minimal /forums/images/graemlins/thumb.gif
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    What year 700r4, the later ones were stronger with all the upgrades that took 7 years to figure out. You will lose not only overdrive but your first gear wont be as low either!
  4. k5guyva
    k5guyva 1/2 ton status
    Oct 26, 2003
    165
    Southeast VA
    I agree with Pauly. Actually you can build a serious 700r4 for just a little more than a 350. And you get a really low first gear and an overdrive too. A 700r4 also has a lockup torque converter.
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    alot of the 80s th350 are lockup converter, and 700r4 are good 87-up.
    you could probably find an adapter for th350 to whatever T-case you have for less than 150 i would think, i assuem you have 208 case
  6. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    You need the adaptor and a longer output on the TH350 othewise the splines don't engage enough. My Th350 came from 80-82 (I think) with the 208 which saves some of the work /forums/images/graemlins/thumb.gif other than that call AA and see what they want for the package
  7. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    I'm with keeping the 700. By the time you buy the kit and swap it over you would probably be pretty close to what a rebuilt 700 would cost. Your 700 is a great tranny, it just needs to be rebuilt and I'm guessing it's an early one so some upgrades will really help. One thing that a lot of people forget is that a 700 is based on a th350. A LOT of the parts in a 350 can be found in the 700 and one of the weakest links in an early 700 is the adopted th350 rear planetary, this is known for failure. I had an earlier 700 that is an 85' box. I have all KINDS of upgrades in mine from late model 700/4L60&80/corvette parts. My new 700 can easely handle 400 to 500 HP, much more than a stock 350 and I only paid $1,300 all rebuilt and installed. /forums/images/graemlins/thumb.gif When you start modifying any tranny from the inside it's going to get expensive.
  8. k5guyva
    Oct 26, 2003
    165
    Southeast VA
    I did the same kinds of upgrades on an '86, and it cost me about $1200. Now, I can beat most of the rice burners off the line when the light turns green. And that's with a tired 305. Imagine what a new 350 can do. Factor in that the K5 is about 2-3 times the weight, and that's really impressive.
  9. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    Where did you guys get your trannies??? Bowtie Overdrives???
  10. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    custom built at a very knowledgable local shop. /forums/images/graemlins/thumb.gif
  11. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    custom built be... ME
  12. k5guyva
    Oct 26, 2003
    165
    Southeast VA
    Mine was built local too. But I told them what I wanted. /forums/images/graemlins/thumb.gif
