700R4 to Manual
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FergsK5, Oct 8, 2002.
  1. FergsK5
    FergsK5 Registered Member
    May 5, 2002
    20
    Moncks Corner, SC
    Anyone know what involved in swapping a manual for a 700R4. It's an 84 K5 and im sick of 700R4 problems and expenses. What do I need and what do i have to change? Thanks.
  2. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    i did this almost exactly a year ago....time wise i spent maybe 3 full days on the swap...kinda hard to pin point how long exactly because i was doin a 1 ton swap at the same time
    but list of things ya need:
    Clutch and brake pedel
    linkages or hydro clutch parts
    sm465 and what ever t case or if ya have the cash the nv4500
    clutch
    flywheel
    and aprox 3 days time
    its not very difficult to do...the hardest part was trying to man handle the tranny its self into the truck..to put the pedals in you will have to remove the steering column..if workin slow...2 hours at most..took me about an hour with searchin for tools
    remove old pedels
    drill holes for linkage or hydro clutch...on my 88 the hydro set up was easy becase the fire wall had dimples marked where the holes needed to be to it was just a matter of drillin the holls and boltin it up
    re install steering column
    pull auto tranny out...remove flex plate and install the new flywheel with clutch
    stab the tranny in the truck and bolt it all up and blead/adjust the clutch and you are ready to rock
    i have been very happy with my manual tanny and would not go back to an auto for wheelin...go for it man...all in all i think i spent 1000.00 in the swap..not to bad considering if i would have had the auto in there i was destroying one a year and the price tag of 1700 a pop /forums/images/graemlins/eek.gif..but it can be done
  3. Lazydog
    Lazydog 1/2 ton status
    Apr 17, 2002
    129
    Phoenix, Arizona
    I did the swap as well. I enjoyed doing it. Like the previous post said, it was mostly a bolt in affair. The hardest part was getting the time all at once to do it. If you've changed a clutch you should have no problem. From the start I wanted my Jimmy to look like a factory 4 speed. I even changed the steering column, and got the reverse lights to work. e-mail is you have any questions
  4. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    I didn't realize you need a shaft bearing. This bearing goes in the crank to allow the transmission shaft to rotate so it won't break.
    Don't forget this piece...
    Oh yeah... th350/203 to a Hydro clutch sm465/203/205. /forums/images/graemlins/laugh.gif
  5. Chaz88K5
    2,979
    Stockton/Lodi CA
    if ya get one for the gasser its a brass bushing and for the diesel its a bearing...i dont know if it really makes a difference or not...
  6. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    Petersen's 4W&OR said use a diesel bearing. said it will last a lot longer than the bushing.
  7. Chaz88K5
    2,979
    Stockton/Lodi CA
    ya know there is really not much point in doin the bearing one the more i think about it...ya gota figure the bushing will last just as long as the clutch...you would prob wipe out 2 clutchs before that bushing would go out....and personaly i would chagnge it regardless when ever it needs a clutch...so i am not seeing any added benifets from the bearing..not to mention the added cost /forums/images/graemlins/rolleyes.gif
  8. Steve_87K5
    Steve_87K5 1/2 ton status
    May 26, 2000
    521
    central NC
    I got rid of my 700 in '94 after 3 rebulids. Extra money spent for the NV4500 was well spent. It was WAS worth the work to get a manual trans. My '87 had the firewall dimples too which really helps locate the hyd cyl.
    Here are the parts I used to get rid of the 700R4:
    http://members.ac.net/~sg/project_PARTS_LIST.txt
    Steve
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    you can do all the pedal and firewall stuff and still be driving the truck with an auto to break the job up some
  10. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    good call Chaz. i hadn't thought about it like that.
