700r4 to NP205
Discussion in 'The Garage' started by Z3PR, Nov 15, 2003.
  1. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I want to run a 700r4 / NP205 combo. Does anyone make the adaptor ??? What else will I need ??? Currently running TH350 / NP203 combo.
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    You will need the TH350/205 adapter and then either use a spacer or change the tranny output shaft to the short shaft sold by advance adapters. If you use the short shaft you will have trouble with the front C/V hitting the tranny pan, but if you use the spacer along with the TH350/205 adapter it will clear just fine.
  3. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    Well if you did that would you have to get new drive shafts?
    lmk
    Nick
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    lmk
    Nick
    [/ QUOTE ]Getting new drive shafts wouldn't be a problem, couple drive shaft shops here locally.
  5. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    I run the shorter output shaft and have no cv to trans. contact although it is close...
  6. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ]How big of a lift ?? I've got 6.5" in the front, and 7" in the back. Would that make any difference ??? I'll probley just use a spacer.
  7. BILLY RAY
    BILLY RAY 1/2 ton status
    Dec 8, 2001
    1,319
    Austin, Tx.
    Here is a link OLD ONE
    link
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    link
    [/ QUOTE ]Thanks for the link. /forums/images/graemlins/thumb.gif
  9. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    yeah, spacer is cheaper and I can run an aluminum deep pan in my tranny with no problem at all. Someday if I want to go back to the old tcase, all i have to do is pull the spacer and go... i dont have to tear apart the whole tranny.
    j
  10. reeser
    reeser 1/2 ton status
    Oct 8, 2001
    434
    Hayden Lake, ID
    what does the spacer cost???
  11. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    about $50 vs the $150+ the AA short shaft is... which requires a complete tranny tear down to install. If you can do it yourself or are gonna have a tranny rebuilt anyway its no biggie... but if you're not thats a lot of extra $ for a shop to do it.
    j
  12. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    Unless you are worried about overall length of the drivetrain I'd go with the spacer. No issues with shaft hitting pan and you can swap back to old case if you want.
  13. reeser
    Oct 8, 2001
    434
    Hayden Lake, ID
    j
    where'd you get yours from. the PO rebuilt my tranny w/the corvette servos and the whole nine yards so i'm not going to tear into it!
  14. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    quote from K5BLT4FUN from another thread...
    "The transmission parts shop that I bought mine from is called:
    A & Reds Transmission Parts
    2501 E Truman Road
    Kansas City, MO 64127
    (816) 483-7337
    I talked to them today and they can sell just the adaptor. The part # 7Q35A and it sells for around $50.00. They said they could ship it for an additional charge. Hope this helps.
    Layne"
    hope it helps. this adapter is not 100% bolt on, pretty sure you do need to grind about an 1/8" off the end of the output shaft for it to mate up just right, but you dont have to take it out of the tranny for that.
    j
  15. Wally81k5
    Wally81k5 1/2 ton status
    Jul 14, 2002
    139
    Cold Lake Alberta
    how long is the spacer supposed to be?
  16. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    spacer mentioned above is 2" thick, IIRC.
    j
