700R4 to T400, who's done it and what else must be done?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by PetaKane, Sep 15, 2002.
  1. PetaKane
    PetaKane 1/2 ton status
    Apr 17, 2002
    530
    Oklahoma City OK
    700R4 to T400, who\'s done it and what else must be done?
    It will bolt up with a 208 case, right? And I'll need a longer rear shaft and have to move the crossmember, right?
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Re: 700R4 to T400, who\'s done it and what else must be done?
    You'll need a different adapter to mate the 208 up with the Turbo 400. The 700R4 has a 27 spline output shaft and a square, 4-bolt pattern at the tail end of the housing. The Turbo 400 has a 32 spline output shaft and a hexagonal, 6-bolt pattern at the tail end of the housing. But the mid-80's 3/4-ton Suburbans came the the 400/208 combo, so you should be able to find the right adapter in a yard. 3/4-ton pickups are probably a suitable donor also.
  3. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    HarryH3 is correct. Additionally, you will not have to move the crossmember or modify driveshafts, because the T400 is close enough ;to the same length as the T700. I know, I did this very conversion in my wife's '90 Suburban. Got rid of the POS t-700 after rebuilding it SIX times. T400 should last FOREVER now.
  4. chillywilly
    chillywilly Registered Member
    May 26, 2002
    70
    northern maine
    Did mine a few years ago...spent $4 or 500 with advanced adapters.Very complete kit if ya aint got time for lookin.
  5. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    Glad to see this post. I picked up a TH400 last month with a 208 attached for $500. Both rebuilt about 1500-2000 miles ago. Anyway, Once I get my engine rebuilt, I plan on swapping the tranny, unless of course I find a buyer for the tranny first. I'm actually thinking of keeping my 208 which is attached to the 700 as a spare, especially since I picked it up rebuilt about 15K miles ago.
  6. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    After toasting my 4th 700/208 I picked up a 400/241 form a 90 burban and eveything builted right up. Only diff is the detent cable on teh 700 and the vacuum line on the 400 but that is nothing really /forums/images/icons/cool.gif
  7. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    You'll have to wire a kickdown switch to go behind your gas pedal for the T400 kickdown. Your 700 uses a TV cable to hooks up to the carb (or throttle body if you have it).
