700r4 to TH400 need advice.
Discussion in 'The Garage' started by Okiemuddog, Mar 3, 2003.
  1. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    /forums/images/graemlins/1zhelp.gif Hello, I am an newbie. I tried searching for the info I need, but couldn't find what I needed. I just bought a 79 with a 700r4 with waiting to go in to it. I don't have an engine to go into it so I am trying to trade the 700r4 for a 350 engine. My question is, I have a 74 Suburban 2wd with a dead engine and a fresh TH400. If I swap out my 700r4 for the TH400 will I be creating a disaster in trying to get the TH400 to fit up to my NP203 T-case? I read on one post that 2wd and 4wd TH400 were different. It just want to know before I trade my 700r4 for the engine if I am better off to just keep my 700r4 and try a different route for an engine. Thanks in advance for the answers. /forums/images/graemlins/confused.gif
  2. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    A 2wd T-400 will not bolt to a 203 t-case. If this 2wd t-400 you have has a 4.5" output like most 2wd trannies it will bolt to a 205 t-case. I'd go for a 205 t-case and use the t-400.
    So you know, a 4wd t-400 has a stronger case but the 2wd is fine for most applications. I have a couple of 2wd tranny cases in my trucks with no problems.
    John
  3. Okiemuddog
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    Does anyone sell an adapter to convert over to the correct spline configuration?
