700R4 towing question
Discussion in 'Tow & Trailer' started by sandawgk5, Dec 19, 2005.
  1. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Is there a break point where it is ok to tow in OD with a 700R4 or if any towing is done it should be in Drive. I have a Saturn that I intend to flat tow across country car weighs about 2400-2600. Could I tow that in OD or is it a bad idea. I have a 40,000 GVRW cooler infront of my radiator so tranny heat is not a concern. Also can anyone direct me to a good and cheap towbar with mounts for a 1997 Saturn SL2.
    Ira
  2. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,862
    294
    Truckee, CA
    Personally, i tow in OD when on flat ground on the highway. If there is any slight incline, or the torque converter unlocks, i put it back in D.
  3. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    yep what he said. but keep in mind 700s havent got asmany clutches in 4th and 1 clutch in the convertor. so any real loads will kill them . if it feels heavy on the truck 3rd is best.
  4. sandawgk5
    Oct 28, 2003
    6,881
    Thanks that is what I thought. I will prolly just pull in 3rd and deal with the RPM. I should be around 2700 with 4.10s and 37s.
    Ira
  5. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Is you r Th700 built? If it's stock I wouldn't tow in OD. If you had an aftermarket converter that builds less heat and modified clutches and valve body I'd say go for it. As long as your gearing was acceptable of course.
  6. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    With those gears/tires... leave it in 3rd to tow. Your tires are already an overdrive.
  7. K85 Octane
    K85 Octane Tacklin' Fuel Premium Member GMOTM Winner
    Nov 2, 2009
    11,405
    791
    Los Angeles/ Pasadena
    OK, Digging this up cause who the hell wants another "towing with 700r4" thread
    I read that 3rd gear is good to tow in. Great, but what if the lock-up doesn't work in 3rd gear? Actually, I should ask if it ever did :) I just know my newer truck locks in 3rd & 4th. My blazer, only 4th.
    And yes, I have the biggest tranny cooler BTO sells. I monitor the temps with an autometer in the pan. Takes for ever to warm up, but temps are steady @ 170, no mater how I drive. Never towed with it though.
  8. kennyw
    Jun 9, 2002
    13,224
    94
    Which gears get lock up is not consistent with early 700R4's. There is no computer to control that stuff, just simple on/off switches at locations like the gas pedal, brake pedal, and internally on hydraulic switches. If it doesn't lockup in 3rd, you just get the equivalent of driving with a TH350.
  9. 79rustyk10
    79rustyk10 3/4 ton status
    Sep 21, 2008
    6,105
    Bikini Atol
    All 5 or 6 of them that I killed :doah: would lock up in 3rd. Are you sure it doesnt? I remember that it wasnt very noticable.
