700r4 tranny mount to crossmember torque spec
Discussion in 'The Garage' started by brucemoose2, Sep 14, 2005.
  1. brucemoose2
    brucemoose2 Newbie
    Sep 13, 2005
    4
    Woodinville, WA
    My 700r4 trans mount was broken so I replaced it with a new one. Anyone have a torque spec for the mount? (Besides PFT) I don't want to wreck the new one! Thanks, Bruce
    PS. I'm working on a 1991 K5 and like the title says, I only need the torque spec for the mount to crossmember nuts.
  2. brucemoose2
    brucemoose2 Newbie
    Sep 13, 2005
    4
    Woodinville, WA
    anyone have a chilton's manual?
  3. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Just use a 1/2" ratchet and tighten as much as you can go. I usually buzz it with my electric impact. Mechs at the dealer usually only use torque specs for engine work. Beyond that, it's just "Get the mofo tight" Trust me, I know........
  4. brucemoose2
    brucemoose2 Newbie
    Sep 13, 2005
    4
    Woodinville, WA
    i tightened it down a pretty good amount, but it felt pretty soft and I wasn't sure of those studs were going to come right out of the mount as I tightened the nuts.
  5. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    Nah, should be good. Just push the tailshaft around to see if you get movement, if not, you're good! Maybe put some loc-tite on the bolts. I've had them fall out of the t-case adapter before.
