700r4 Tranny or NP 208 Problem?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dgface, Oct 20, 2002.
  1. dgface
    dgface Registered Member
    May 12, 2002
    39
    McDade,Texas
    Newbie here so be easy please! 87 Blazer will not move when put in drive or reverse. Does nothing in reverse but rocks the truck in drive but that's all. Checked fluid and filled to correct level. Raise the rear tires and it will spin in drive but nothing in reverse. Probably tranny but just asking for ya'll's expert opinon. Thanks! /forums/images/graemlins/1zhelp.gif
  2. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    It sounds like a transmission problem. When the truck is in park, does the transmission hold it from moving like it is supposed to. If it does the transfer case is probably OK, if it were something in the transfer case slipping it would let it move when pasrked also. if it only slips when trying to move in drive or reverse it is probably a transmission problem.
