700R4 Tranny
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MA87K5, Apr 3, 2001.
  1. MA87K5
    MA87K5 1/2 ton status
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    I was checking my engine by powerbraking the tranny when it felt like the tranny let loose. Nothing popped or made a noise. Now I give a lot of gas just to start to roll. Does this mean that it is toast?
  2. Truckfan2
    Truckfan2 1/2 ton status
    Apr 10, 2000
    343
    Northern IL
    ANother question... has anyone heard of breaking the input teeth off the input shaft on these transmissions? Supposedly that is with I did to mine... any one have an extra 700r4 sitting around that they want to get rid of?
    Have been stuck (once) as of 8/12/00
  3. Daveytree
    Daveytree Registered Member
    Nov 11, 2000
    57
    Kingman Arizona, U.S.A.
    The problem might just be in the torque converter.
  4. bandit
    bandit 1/2 ton status
    Mar 4, 2001
    690
    Ellensburg Washington
    hmm sounds like you might of fried pull teh dip stick and smell the fuild it will smell fryed never heard of breack teethe but once saw a ford the rolled 3 times teh broke the input shaft
    Bandit
    (Your right i dont understand the jeep thing)
  5. Truckfan2
    Apr 10, 2000
    343
    Northern IL
    Me TC??? I was thinking that because again, supposedly, those torque converters are notorious for thier cases "expanding"... anyone know if there's any truth to that???
  6. Blazerblk
    Blazerblk Registered Member
    Jan 23, 2001
    15
    Chicopee, Ma
    AKA MA87K5
    Thanks everyone for the replies. I talked to Rossler Transmission and they told me that it also might be the torque converter. I priced one at $65.
  7. freeforever
    freeforever 1/2 ton status
    Feb 21, 2001
    305
    Missoula, MT
    mine did the SAME thing...it was the TC...not to expensive. And thats a good price
    "Fool me once shame on you...fool me twice shame on me"
    "A closed mouth gathers no foot."
  8. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> Slow down , Bandit !
    L8r,
    . Riz . <A target="_blank" HREF=http://www.geocities.com/rizmonkey>http://www.geocities.com/rizmonkey</A>
  9. Emmettology 101
    May 9, 2000
    8,126
    FL
    A TC for $65??? Man, they usually run about $200 for the 700...
    <font color=green><A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A></font color=green>[​IMG]
  10. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    Heard of breaking the splines off the forward input clutch pack/sprag, but if that happens, then no forward. Hardened sprags usually fix this. A good replacement stock torque convertor (1654 stall) for a 700r4 runs about $70 buck from a supplier. Get the same unit from a tranny repair place and their markup will run you about $170 for the same item from the same supplier that you got the $70 price from.
  11. dyeager535
    26,975
    I know the early 200-4R's had un-hardened stator supports, which also mate up to the converter, and it is/was common for the teeth to wear off completely. I'm sure the early 700 had the same problem.
    Dorian
  12. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    <font color=red>DON'T DRIVE IT ON A BAD CONVERTER!!!<font color=black> That will toast the rest of the trans, and you'll have a fresh converter on a trashed trans...[whoops] Just make sure to get the trans powerflushed (best), or change the fluid & filter a couple times back-to-back (okay), to avoid contaminating the rest of the trans.
    [​IMG] Semper Maintenance!
  13. Blazerblk
    Jan 23, 2001
    15
    Chicopee, Ma
    AKA MA87K5
    Thanks everyone. But I think that I'll just change the tranny all together. I really don't want to change the converter and find out that the tranny is bad, and take it all apart again. I have very limited time. I bought a 92 tranny that came from a step side pickup for $400. The fluid is nice and red. The truck didn't look like it had alot of miles. It just had the front destroyed.
