700R4 Trans Pan
Discussion in 'The Garage' started by westn11, Jun 14, 2006.
  1. westn11
    westn11 1/2 ton status Premium Member
    Dec 11, 2003
    333
    21
    Northern VA
    What aftermarket transmission pan are you guys running? I want a cast aluminum one with a drain plug. My transmission is already out of the truck and I cant remember if I need to worry about clearance problems with a crossmember, ect.
    thanks
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I was thinking of doing the same but then thought that if anything ever decided to hit my tranny pan fairly hard i would rather have a steel pan dent than an aluminum pan crack or break. You can still drive with a dented pan but try driving with no fluid after the pan cracks or breaks and leaks out all your fluid.
  3. lamberthkp
    lamberthkp SITFU Premium Member
    Jan 17, 2005
    1,468
    16
    West TN
    good point. maybe one of those kits were you add the drain plug, that way you can add it to the steel pan. that might work forim
  4. westn11
    Dec 11, 2003
    333
    21
    Northern VA
    "i would rather have a steel pan dent than an aluminum pan crack or break"
    Good point, I didnt even think of that.
  5. kwissman
    kwissman 1/2 ton status
    Jan 14, 2006
    118
    Austin, TX
    I think the pan off on the newer 4L60E should fit a 700R4 and already has a recessed drain plug. That is what I am going to try if I ever get around to it.
  6. WhiteBurb
    WhiteBurb 1/2 ton status
    Mar 10, 2005
    307
    Louisiana
    I added one of those drain plugs from B&M to my 700 pan. It has made filter changes a lot cleaner. I got it for about $8 at the parts store.
