700r4 trouble *please help*
Discussion in 'The Garage' started by tweaker, May 23, 2005.
  1. tweaker
    tweaker 1/2 ton status
    Mar 21, 2004
    263
    Modesto, CA USof Freakin A
    what does clunking/rattling noise mean? the trucks an 83 k5 blazer diesel conversion(400sbc). is that a bad noise or a really expensive noise? and it does go away when engaged in gear and used to go away when it was warmed up.
    thanks in advance
    Dillon Carson
  2. diesel4me
    Jul 24, 2003
    17,537
    921
    Massachussetts
    might bee...
    Could be loose torque converter bolts,or a cracked flexplate!....among many other things..check those 2 first... :crazy:
  3. 1985K20
    1985K20 1/2 ton status
    Jan 11, 2005
    191
    Quebec,Canada
    could be loose flexplate bolts also but it would keep doin it while warmed up... :thinking: Check em anyways :D
  4. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    If the converter bolts look good (and you cant see any other problems) get ready to replace the converter. Mine started rattling and would stop one you got up to speed (4th gear) and the lock-up engaged.
    Yes, diesel converters are about twice the cost of a gasser :frown1:
    I replaced it before it blew up.
  5. tweaker
    Mar 21, 2004
    263
    can i put a gas torque converter on a diesel 700r4 and make it work right?
  6. 79chevyk10
    79chevyk10 1/2 ton status
    Dec 14, 2003
    612
    Central Coast
    Hell yeah. You're already runnin a gas motor. The only difference on a diesel torque convertor and a gas is the stall speed. The gas being taller.
  7. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Oh man, that sucks. If it's nothing simple take it down to Kevin at Modesto Transmission. Have him build you a "Bobby special" 700, like mine of course. :D Kevin knows his stuff....
  8. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    700s are all junk,,junk junk junk :)
  9. tweaker
    Mar 21, 2004
    263
    well, finally got to doin the deed this last weekend. and guess what. it was the flex plate cracked around all the internal bolts and was slacking back and forth. then while removing the tranny and t-case, peeuu :crazy: . rotten egg smell. bad trans. so everyone was right. they were all bad. so i swapped in a new flexplate and replaced the trans with an s10 700r4. oops :mad: . wrong shift pattern. so now back to the drawing board. need floor shifter. oh well.
    thanks again all for the ideas
    Dillon Carson
  10. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    S10 700r4 have less clutches and a smaller case to fit in the smaller chassis. DO NOT USE THAT IN YOUR FULLSIZE!
