700r4 vent line
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84k5, Feb 7, 2002.
  1. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    I extended the 208 and axle vent lines up under the hood, but I cant find where the vent on the 700r4 is. I'm assuming it is up high and I'm just not seeing it. A little help would be great.
    Also, the 700r4 and rear 10 bolt leak a little fluid. The tranny barely leaks, theres just a little fluid on the pan, and the 10 bolt drips a little, but not very much. I was wondering if fluid can get out, will water be able to get in?? Thanks.
    Brian
  2. Innerpiece
    Innerpiece 1/2 ton status
    Feb 22, 2001
    145
    Mississippi (Yee Haw)
    The vent is on the top of the case, just aft of the bell housing ... usually a little plastic tube that sticks out a couple of inches and kind of lays flat against the case.
    As for the leak -- Make sure it's tranny fluid ... my rear seal leak was getting into the bell housing and onto the TC and getting slung around ... looked like it was a tranny leak (other than it was oil and not TF)
