700R4 where there was none....
Discussion in 'The Garage' started by sled_dog, May 31, 2005.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Alright I have a 700r4 sitting in the garage. Considering using it in the S10. The low first gear and the overdrive are very strong draws. Problem is I don't know what it would take to throw it in. The S10 has a 700R4 but thats a different bellhousing and it and the 2.8 are going bye bye. So what will it take to setup a 700R4? TV cable setup attached to the throttle on my carb.... what else? I looked at it this weekend and didn't note any electrical hookups. I'm guessing its an older 700R4 and doesn't have some electronic controlled torque converter lockup. Is that impossible?
    I sure wish my rotating assembly wasn't already balanced with that flexplate, if it weren't I'd be hunting down something like a T10 to 241 adapter :D
  2. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    All 700R4's will have an electrical hookup on the drivers side of the case. You should be able to swap in the correct 700R4 (bellhousing) and just make sure the TV cable is hooked up and adjusted properly and you're done.
  3. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    It should not be much of a problem at all because you all ready had a 700 in there so you have all the wiring and correct collant lines.
