700R4 - where to get a good one?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 89beast, Mar 12, 2003.
  1. 89beast
    89beast Registered Member
    Jan 17, 2003
    Muskego, WI
    I know this question has been asked (I spent a few hours using the search button), but I still don't know where to find a good deal on a 700R4.
    Needless to say, my 89 k5 tranny needs to be replaced. After 160k, 3rd and 4th are gone.
    From what I learned from searching, I would like to get a GM rebuilt. But where is a good place to get one of those?
    I also saw mention of using a GM high performance version of this tranny, and I think I found the one that was mentioned, only it's a 4L60E (police package 350 Vortec powered Chevrolet Tahoe). Would that work or am I looking at the wrong one?
    Heck, I'd love to swap in a SM465, but I don't know which doner trucks to look for, or what I would need to do to keep the TBI chip and speedo happy. Where would be a good place to find that info?
    I'm running 33's with 3.42's right now, would that work with a 465?
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    Northeast Nevada
    You can get a GM 700r4/4l60 from your local chevy dealer. I think they are still around $1200. and come with a good warrenty.They have all the upgrades.
    Or check out these 700s from:700r4.com They build good trannys and are resonabley priced.
    I highly recomend you get a new torque convertor and a good trans cooler to go with your tranny.
    You cant use a 4L60E they are computer controlled and your computer wont support it.
    I am pretty sure you can swap in a SM465 without affecting the computer. 89s have a mechanical drive spedo/VSS so you dont have to worry about the VSS sensor in the x-fer case.
    As long as the drive cable is hooked up to the x-fer case it should be fine.
  3. 84K5cedric
    84K5cedric 1/2 ton status
    Aug 2, 2002
    Austin, TX 78660
    I got this one from http://www.700r4.com . I love it! I was going to go Level2 but they talked me up to level 3 since it has the hardened parts. With big tires every bit will help. You will DEFINITELY need to get a cooler to run in-line with your stock radiator tank. I got this one from Summit. If you don't have a tranny cooler guage, you should consider one of those too! Everyone gives the 700r4 a bad rap, but heat is the killer of these transmissions and the better care you take of it, the longer it will last.
