700r4 wiring question
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by naranja72, Aug 12, 2003.
  1. naranja72
    naranja72 1/2 ton status
    Jan 6, 2002
    110
    vancouver, bc, canada
    Has anyone used a wiring harness so that the torque convertor will lockup if you're running a carb. If yes, which brand did you use and what, if any, problems did you have installing this.
    Thanks,
    Marc
  2. 73K5Kid
    73K5Kid 1/2 ton status
    Sep 24, 2002
    583
    chandler az
    I am using the TCI kit that I purchased from summit. I did not install the internals in the tranny. I had my tranny shop install it why they were installing my output shaft. The kit gives you the choice of running a toggle switch so you can manually switch the converter off and on. I chose not to use it. All you have to do is hook up 2 wires one to a 12v source and another wire to the outside of the tranny harness that connects to a module. You then run a vaccum line that connects to the module and the carb. Pretty simple.
  3. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
  4. naranja72
    Jan 6, 2002
    110
    thanks for the replies
  5. Chris_T
    Chris_T 1/2 ton status
    Mar 17, 2001
    718
    Saskatoon, SK
    Mine is a very simple one wire/ground setup. I don't remember what pins they are, but the convertor is either locked or unlocked, based on my toggle switch.
