700R4 with a 205
Discussion in 'The Garage' started by Nonesuch, Jan 16, 2003.
  1. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    Will a 205 off of a th350 work on 89 blazer with a mechanical speedo? If not, what do I need to make it work?
    Justin
  2. K5BLT4FUN
    K5BLT4FUN 1/2 ton status Premium Member
    Feb 28, 2000
    496
    Peculiar, MO USA
    In a brief answer, Yes. You will have to do one of two things to mate the 205 to your 700R4. One, install a Advance Adapters 700r4 output shaft in the transmission to give it the same stickout length of a TH350. Two, you can purchase a spacer that will go between the 700r4 and the transfer case adapter, again giving you the same stickout length you need. Do a search on this site. This topic has been discussed several time.
  3. Nonesuch
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    Thanks for the reply. In my haste for an answer I did not "think" about doing a search.
    Justin
