700r4 with a 208? 205?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ugly_blazer, Apr 25, 2004.
  1. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    I have a 205 and adapter for a th350, and a 208 and adapter for a 700r4 with the spacer used for a th350. What length output shaft is needed on the 700r4 to work with either case? A friend has a 700r4 from an 89 2wd truck, it has a tailshaft housing about 5 or 6 inches long. Would this transmission work with either t-case or does the 700 use a special length output shaft for 4x4?
    Thanks, ugly_blazer
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The output shaft on a 700R4 from a 4WD is several inches shorter than the one on a 2WD. /forums/images/graemlins/frown.gif
  3. ugly_blazer
    Apr 12, 2004
    1,214
    Ok, that's what I was afraid of. Thanks.
