700r4 with no gears?
Discussion in 'The Garage' started by Russell, Apr 6, 2007.
  1. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,923
    333
    Fort McMurray, Alberta
    Hey guys!
    What could cause a 700r4 to loose absolutely all mobility, putting it into drive, or reverse results in absolutely nothing, as if the truck was in neutral.
    I'm thinking the torque converter might be screwed up...
    What do you guys think?
    Russ
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    im guessing pump if its not making any noise. converter would make noise as would any other hard part in the tranny.
  3. Russell
    Jun 23, 2000
    7,923
    333
    Wouldn't the engine really labour against the torque converter if the transmission's pump was locked up?
  4. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    Pull the inspection cover and make sure that the convertor bolts are still there and tight and also that you can't spin the convertor by hand. If the bolts are there and you can sping the convertor by hand then you have a busted flexplate.
  5. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Filter blocked/broken. Fluid level low? Linkage still attached?
  6. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    I have had a torque converter shear and leave no evidence anything was wrong. Power one minute...clunk.... no power at all, like it was just stuck in neutral. No other evidence other than the one clunk when it let go
  7. Russell
    Jun 23, 2000
    7,923
    333
    Thats why I figured it might be the torque converter -- The lady said it made a heck of a clunk and thinking it was a busted crank or something more serious, she just killed the engine, then drug it home and listed it for sale...
    I'm about to go out and tear the running boards off so I can actually get underneith the thing, and do some diagnostiscs :)
  8. buefchris
    buefchris 1/2 ton status GMOTM Winner
    Dec 28, 2005
    1,503
    buena park ca.
    Lotta miles? Front pump.:(
  9. Russell
    Jun 23, 2000
    7,923
    333
    Nope, next to no miles, rebuilt less than 6000 miles ago infact...
  10. buefchris
    Dec 28, 2005
    1,503
    buena park ca.
    It's to my understanding the front pump is one ofthe frist things to go. Mine slowly went 4th 3rd 2nd 1st in a matter of minutes. didn't even attempt reverse.:confused:
  11. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the pump is directly connected to the engine, so if it did lock up, the starter would have a hard time to turn over. that said, ive never seen a pump lock up so i won't spin. my experence with the pump is when it goes there is little to no noise and when it does, you have nothing at all.
    you said there was a big clunk, i have seen the input shaft seperate from the input hub assembly, but seems fairly rare.
  12. Russell
    Jun 23, 2000
    7,923
    333
    Found the problem when I took the inspection plate off :)
    Three bolts with boogered up heads fell and hit me in the head as soon as I dropped the plate off, torque converter freewheels, lol
    I'm going to bolt it back up, and hopefully I'll have a perfectly good transmission :D
  13. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    nice looks like a good score
  14. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Don't you just love it when that happens!:D
  15. Russell
    Jun 23, 2000
    7,923
    333
    Well, things never go that easy :P One of the bolts is busted off in the torque converter, and there is some nasty wear on the flywheel.
    I'm going to drop the tranny and replace both with a set I've got sitting in my parts pile, gonna take a couple hours, but whatever, then this truck is technically done...
