700r4 wont stay in gear
Discussion in 'The Garage' started by racrxrm125, Sep 20, 2005.
  1. racrxrm125
    racrxrm125 Newbie
    Dec 8, 2002
    i have a 700r4 that i just had rebuilt not to long ago and ever since i have had the truck when ever i put it into first manually it always shifts out and into second by itself one it revs to a certain point. this problem really screws me up when i am off roading. i would appreciate aany feed back on what the problem is or if it is just that model tranny and how to fix it. thank you
  2. diesel4me
    Jul 24, 2003
    17,540
    930
    Massachussetts
    might be normal??
    I know some TH400's will upshift into second automatically,even if the shifter in manually pulled into "low",it shifts at 5200 rpm!..its a factory designed thing built into the valve body,once pressure reaches a certain limit...maybe the 700R4 is set up in a similar fashion?? :crazy:
  3. 89newtome
    89newtome Registered Member
    Apr 28, 2005
    23
    Enfield,CT
    i think it is normal
    I believe this is a normal anti self destruct thing. My 700 does the same thing. Everything I read points to it being normal. I have been looking at buying this 700r4 ratpor trans. from Performance automotive and transmission. 700raptor.com. its built heavy duty and has a manual valve body. I havent found anyone who has heard of this trans though so i don't really know if it worth the money.
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    it is perfectly normal. when in manual first, at about 40-45 mph(in high range and stock gears/tires) it will shift into second. im preaty sure the reason is to prevent blowing the motor up because of the low first gear.
    even the manual valve bodies have this "feature", at least all the ones ive seen.
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Then I guess you have searched on this site. There are at least 2 people on CK5 that were VERY unhappy with their cRaptor transmissions. Do a search on craptor and see what ya find... :(
    If I was gonna deal with anyone long distance it would be the folks at www.bowtieoverdrives.com
