700r4?
Discussion in 'The Garage' started by southernspeed, Apr 13, 2005.
  1. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I've seen this on ebay over here. It's advertised as an early 80's 700r4. Is it? Are the early ones ok after a rebuild?( I would put what ever it would need in it) (I know they had a few probs as std) and can it be converted to 4x4 use?
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i see nothing :dunno:
    the early 80s 700r4 are only good if the rebuilder did all the upgrades required. not all rebuilders put the all upgrades in them.
  3. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    'course you didn't....I forgot to attach them! :haha:
    Sorry about that!! :grin:
  4. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    that is an earlier 700r4, can't tell you the exact year, but its deffinetly pre 87.
  5. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    So if I rebuilt it , are there parts available to uprate it to a later spec one? And can it be converted to 4 wheel drive use?
    Or do you think I should just wait for a late 4 wheel one to turn up?
    Thanks.
  6. dyeager535
    26,981
    Some of the tranny builders here can probably comment, but the casting was actually changed in '87 or '88.
    I think no matter how hard you try you can't "upgrade" a tranny built before that to the same level as ones after.
    Not saying the early ones can't be improved/built strong, but the later ones will come "upgraded" already with some parts.
  7. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    I would not even bother with that one. The newer ones are so much better to start with. They have a 30 splin input, 10 vane pump axurilty valve body. Look for a casting line near the spot where the coolant lines go into the tranny this is a sign of the newer casting whit good internal parts.
    this site has a lot of info
    http://www.highperformancecars.com/crosley/700id.htm
    and so does this one
    http://www.4wheeloffroad.com/techarticles/63498/
    and yes you can convert a 700 to four wheel drive all you need is the 4x4 output shaft GM wants about 120 for them
  8. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I would pass on that one. IMHO you will never make an older 700r4 as good as the newer upgrades model.
    This site will help you to ID the good 700s. Also has some other good info on them.
    Hope that helps.
  9. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Thanks to all for your advice! :)
