700r4....
Discussion in '1982-Present GM Diesel' started by 79k20350, Jan 13, 2006.
  1. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    So the next project is a turbo 6.2 85 k5. im gonna be running 38's & 1 tons w/ 4.10's. really i gotta keep the od to be able to get a decent highway numbers (right around 1800) then i got thinking. isnt a major problem, w/ the 700r4 that every thing was geared way to high? i thought that was a big problem (like 308's and od) so to get the rpms we need arent we basically dooinng our trannys from the begining?:confused:
  2. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Well I'm running a 700R (behind a 6.2 w/turbo no less) spinning 38x15 with a 4.56 gear. I do have to drop out of OD alot if I'm on the highway and hit a pretty good size hill (we got HILLS) and/or if I'm not pushing 60+mph. My 35" tires worked better with my OD/gear combo.
    Now with your 4.10 gear I think your right about not wanting an OD (.70).
    Tire Gear Trans RPM@65
    35" 4.56 .7to1 1992
    38" 4.56 .7to1 1835
    38" 4.56 1to1 2620
    38" 4.10 1to1 2356
    38" 4.10 .7to1 1650
    'Could build a pretty stout TH400 with maybe enough left over to flip for the lower 1st gear-set :thinking:
    http://www.4lo.com/calc/gearratio.htm
  3. 79k20350
    Nov 22, 2004
    7,757
    Ct
    i was figuring a 38x15x16.5 radial at 70 would be 1825. pretty much wear we want to be. im still thinking of 465 though...hmmm...
