700r4
Discussion in 'The Garage' started by johnathan, Jun 14, 2006.
  1. johnathan
    johnathan 1/2 ton status
    Sep 26, 2005
    376
    Ocean Springs,MS
    My buds 89 pickup,700r4 is stuck in first.He pulled the pan last night ,said everything was fine,no burnt fluid,metal etc.Is there anything simple to look into before he goes for the rebuild? I checked his TV cable,it looked to be adjusted right,but it felt wierd like it did'nt catch until half pedal.
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    look at the governor gear, its under the small steel cover on the driverside near the rear of the tranny. pull it out, the gear is usually green, blue, or yellow. if its chewed up thats you problem, the gear is about $4.
    there is a very light spring up until about half throttle, then a heavier spring takes over. the light spring pretty much is just to return the cable and valve.
  3. johnathan
    Sep 26, 2005
    376
    Ocean Springs,MS
    Thanks for the reply,I'll check the governer gear.
