700r4
Discussion in '1982-Present GM Diesel' started by childs, Jul 21, 2001.
  1. childs
    childs Registered Member
    Mar 15, 2001
    19
    delaware usa
    My 84' diesel jimmy is having trans problems. Shifts hard but have to rap it up before it will shift. Should I rebuilt it and update it or swap it out? Do the torque converters go bad often? When it is in gear it doesn't seem to slip. I will try to deal with it some in the morning.
    DE k5
  2. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Something amiss with your TV cable? I heard that if its out of adjustment you can have some problems.
    SK-15
    J**P...it's whats for dinner!
    Roads? Where we're going, we don't need any roads!
  3. RLBstein
    RLBstein 1/2 ton status
    Jul 2, 2000
    179
    Pensacola, FL
    Find where your TV cable connects to the engine. There is a button on it (sort of). With the engine off, push in the button and move your throttle to full. Then release the button and then the throttle. That will set it back to normal. You might have to adjust it back a little to get it perfect. I had the same problem with mine and this worked for me.
    85 Blazer on an 82 chassis, 6.2L Diesel, ORD flip, 35's with no cutting on a 4" lift.
  4. Guest66
    Guest66 Registered Member
    Jul 8, 2001
    50
    Utah
    My 700 tranny was shiftin real hard also but i had it rebuilt and now it shifts real smooth and doesnt have any slip anymore
