700R4
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by radar, Nov 28, 2001.
  1. radar
    radar Registered Member
    Oct 28, 2001
    26
    If my 700R4 has a 3-4 pack in how do i know and what does that mean.
  2. tori89k5
    tori89k5 1/2 ton status
    Apr 12, 2001
    946
    Pismo Beach, California
    What exactly are you reffering to ? Yes. I does have a 3-4 clutch pak
    1990 K5 4" lift, 33's, 3.73's Raptor Tranny and Velvet Rides....
  3. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    A 3/4 clutch pack refers to the clutch pack that holds the power during the 3rd to 4th gear changes.They fail frequently in stock 700R4's.You'll see H/D 3/4 clutch packs advertised.They increase the number of clutches in the 3/4 clutch pack, this is suposed to reduce the failure rate as there are more clutches to take the abuse.Only way to know if you have a H/D 3/4 clutch pack is to take the tranny apart and count the clutches,The H/D units should have 7-9 clutches.I think stock 3/4 clutch packs only have 4-5 clutches.
    <font color=green>BobK<font color=green>
  4. Blazinit
    Blazinit Registered Member
    Nov 26, 2001
    29
    Minnesota
    I may not be able to tell you if you have it, but if it runs in and out of OD like mine does, then you DEFINATELY know you don't!
    '84 K5 Blazer 4"Rancho R/B w/Quad Diamond Back front 350/TH700r4/NP208/35" BFG AT/10 bolt F&R
    Washington, USA
