700r4
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by archer, Aug 19, 2000.
  1. archer
    archer 1/2 ton status
    Aug 17, 2000
    136
    tn
    I just drained my transmission and installed a new filter. It's a 700 r4. How much fluid does this transmission take after this service. My owner's manual doesn't tell me. It's an 85 k-5. Any help is appreciated, Also, I have the gov-lock, I just installed new spider gears, does this thing require a special anti-friction addative for the clutch-packs? Thanks for any help!
    "who dares wins"
  2. sosamantx
    sosamantx 1/2 ton status
    Aug 14, 2000
    393
    somewhere in Texas
    Why don't you call your local auto parts and ask how much fluid that it need. I am guessing 4-5 quarts and then check it. I work at Autozone part-time and we can look that up on the computer. I don't know the answer to the other question though. - Steve
    Steve Sosa a.k.a. "sosaman"
    http://sosaman.home.texas.net/carpics.html
  3. BigBadBowTie
    BigBadBowTie 1/2 ton status
    Apr 6, 2000
    160
    AZ
    The exact amount varies, put 3-4 quarts in then get it up to operating temperature. Then place it in neutral, check the fluid. From this point only add in pint amounts (half-quart)at a time till you got it right. I'd also check it for several days, as the fluid cirulates you may need to top it off.
    <font color=purple>Rick
    86 K-5</font color=purple>
    http://www.BigBadBowTie.ColoradoK5.com
  4. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Just curious why did you change the spider gears ?
    TIA
  5. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    A 700r4 takes about 12 qts of fluid, total. (About 3-4 in the convertor). I would put in 4-5 and go from there.
    creepin' and crawlin'
    Jim
