700R4?
Discussion in 'The Garage' started by MontanaLifted, Aug 27, 2002.
  1. MontanaLifted
    MontanaLifted 1/2 ton status
    Aug 27, 2002
    171
    Is it easy to bolt on (and run) a 700R4 to early year K5?
    I've heard there are tricks for vacuum pressure. Something about if certain small things aren't done it'll burn up the tranny.
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    700r4s don't use a vacuum modulator.
  3. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    700R4's use a Throttle Valve Cable "TV cable" to set shift points. If it is not installed and adjusted properly, the tranny will self destruct quite rapidly.
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    No vacume to worry about on a 700.
    BUT
    You will need all the hardware to hook up the TV cable. It is very important that the TV cable be hooked up and adjusted properly.
    You will also need a torque convertor lock up kit. Its no use installing a overdrive tranny with out the lock up on the torque convertor working. Besides if it dosent lock up it may build up heat.
    Summit sells both these kits.
