700r4 ?
Discussion in 'The Garage' started by 79k20, Feb 18, 2003.
  1. 79k20
    79k20 1/2 ton status
    Oct 15, 2001
    144
    s.e. kansas
    What would cause a 700r4 to pause when shifted from park to reverse or reverse to drive? It pauses for a second and then engages.
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Well, mainly it is the build-up of line pressure. If it's an abnormally long stall - check the fluid level, it may be low. Otherwise, there's nothing to worry about.
  3. Can Can
    15,555
    156
    Cochrane, Alberta, Canada
    Heavy is right on the money.....it might also be caused by a sticky valve(is this the right term?). Next time you service your tranny you might want to add a can of quality tranny conditioner and see if that helps.
  4. bee32
    bee32 1/2 ton status
    Aug 6, 2001
    401
    Virginia Beach Va.
    Valve is correct(Throttle Control Valve)or TCV. IMO you guys hit it on head the with the fluid level and TCV. /forums/images/graemlins/thumb.gif
  5. Marshall
    Marshall 1/2 ton status
    Apr 8, 2002
    204
    LiveRmore,CA
    Mine does the same thing i thought that was nomral. Fluid is brand new....i have right amount in it also. my other 700r4 tranny did the same thing.
  6. 79k20
    Oct 15, 2001
    144
    s.e. kansas
    Thanks guys i'll check this stuff out.
  7. 89K1500Chevy
    89K1500Chevy 1/2 ton status
    Nov 9, 2002
    645
    Georgia, Fayetteville
    yes mine does the same thing ive noticed a lot of cars and trucks do that id think it would be the pressure buildin up in the lines. /forums/images/graemlins/deal.gif /forums/images/graemlins/truck.gif /forums/images/graemlins/usaflag.gif www.zombieoffroading.8m.net
