70cc combustion chambers
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JoseK5, Mar 12, 2002.
  1. JoseK5
    JoseK5 Registered Member
    Dec 12, 2001
    62
    Lebanon
    Does any one know the difference between 64cc heads, and 70cc heads? I've decided to upgrade to 383 with edelbrock heads, but I need some clues on cylinder heads, and piston compression ratio.
  2. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    Most pistons and compression ratios are based on the 64cc heads.
    For instance, I got 11.5:1 pistons... BUT i put on my 76 cc heads, which gave me a 9.2:1 compression ratio.
    So now, if I want performance heads. I will have to run 100 octane gas. It is hard to find good performance heads that are 76cc.
    It's all fun...
