71 is 8 lug now!
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by MNorby, Sep 16, 2006.
  1. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    got my d44 front put together using parts from 3 different axles to make 1 front with 4.10s, 8, lug and the best hubs and shafts and otehr goodies from the 3 axles. Thanks to MTChevy for the deal on the 8 lug stuff and a local friends for the 4.10 stuff. Here is is sitting on an old set of 305s (33s). Rear is a bit squaty not after the zero rates in front to take front an inch and half forward and give it some pinion shim so I will install the overloads into the 56s rears and if needed cut an extra set of overloads down into a zero rate deal for the rear. This has no fuel tank in the rear. I am getting a 31 gal from a gen 2 blazer so with that extra weight I'm sure it will need teh extra.
  2. MNorby
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    photochop of the front of each fender being trimmed. Makes axle look more centered with the front of fender trimmed to match angle of the rear of the fenders
  3. MTChevy
    MTChevy 3/4 ton status Premium Member
    May 6, 2005
    7,141
    78
    Great Falls, MT
    thanks for taking that axle off my hands!!! i got a 14BFF for cheap too if you know anyone who wants it
  4. MNorby
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    Hey no prob, thanks for makin me a deal
    Here is some front end bling. Note, I needed longer u-bolts after the zero rates so only have one attached on each side till I get my other ones "blinged up" for it. Axle also got dusty after a couple days in the shop.
  5. MTChevy
    May 6, 2005
    7,141
    78
    Great Falls, MT
    wow you definatly made it look good!
  6. vtblazer
    vtblazer 1/2 ton status GMOTM Winner
    Sep 30, 2003
    2,471
    Central VT
    What's the final tire size your going with?
    Have you found time to shave that 14FF yet? :wink1:
  7. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    Looking good, quick transformation.
  8. MNorby
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    Haven't shaved the 14FF, just got it under there so I can get it driving here soon. Plan was to collect parts to disk brake it later too but I already have those parts now except for cutting the brackets so when I do that I will prob shave too. I have some old 35s off my towrig I may run, a friend has some 36s I could pick up and other friend wants to trade me a set of 38 ground hawgs for some old parts I may run them. Biggest thing is this is my ultimate budget wheeler so don't wanna spend much $$$. Ultimately I would love to run 37 MTRs on it.
