71 K-5 top Questions?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by gassman, Aug 4, 2000.
  1. gassman
    gassman 1/2 ton status
    Jul 12, 2000
    131
    Quincy Cailf, Plumas County
    How do you remove the top of a 71 K-5. See the bolts in front and back. Is there any in the middle. Help.
  2. TheBlazerKid
    TheBlazerKid 1/2 ton status
    Apr 26, 2000
    259
    Raymond, Washington
    Ask biggrey 71 he just had the top off of his, I have a 71 as well but I havent had the top off yet.
    Your right I dont understand the jeep thing!?
  3. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    From your post, I assume you have a double wall top. There are several bolts holding it on that come up from the bottom. You have to remove the rear side panels to get to them. If it's a single wall top, all the bolts go down from the top side.
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
  4. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    4 bolts hold the top to the windshild ( 2 though the visor mount,2 behind the visor in to the frame) 6 bolt down each side (from the bottom for dubbel wall, from the top for singel wall) plus one on each side at the back. I take mine off each spring and replace it with a softtop. Take care of the top as the warp easly stop them flat on block not on one side or such. My door fit better whit the top on than when off and there is less body flex with the top on.
    I understand the jeep thing I drive a BLAZER!!
    Ken
  5. gassman
    Jul 12, 2000
    131
    Thank's for the infor. It must be a Double wall top because I can't see any bolts on the inside. Is the double top better in the winter for mosture on the inside of the top.
  6. blazer72
    Apr 13, 2000
    939
    KCMO
    The dubbel way was just on of t00 types there is reson stated any place that I haves seen as to why both tops showed up only in 70 and 71. the singel wall was used in 69 to 71 with the dubbel wall showing from 70 to 72, the 73 and up uses similer top to the dunnel wall.
    Ken
