71 k5 oil pan gasket change...
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by **DONOTDELETE**, Apr 3, 2003.
    What is the easiest way to get the oil pan off? Do I need to take that crossmemeber all the way off? Should I support the motor with something? Is there an easier way?
    thanks,forrest
  1. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    Support the engine from above and pull the cross member all the way out. /forums/images/graemlins/thumb.gif
  2. '72brett
    '72brett 1/2 ton status
    Dec 3, 2002
    166
    northwest Iowa
    take the carb off, and then bolt on a "motor hat" many places sell em, but its very easy to make your own (if you don't already have one) hook up a chain hoist to that, or a cherry picker, and lift it up (be careful that you dont break your distributor cap against the firewall)
    Here is the way I'd do it.
  3. mastercraftkpk
    mastercraftkpk 1/2 ton status
    Mar 12, 2003
    192
    Houston, TX
    There is no real "easy" way. You want to be sure to have full access to the pan w/ room to work, so take the crossmember all of the way off w/ engine supported from above. While you are at it, go ahead and replace motor mounts. They are prob orig. and it is a great prevent step.
    Before you put everything away after replacing the oil pan, check for leaks with your equip still handy.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
