'72 12 bolt rebuild questions
Discussion in 'The Garage' started by mastercraftkpk, Apr 17, 2003.
  1. mastercraftkpk
    mastercraftkpk 1/2 ton status
    Mar 12, 2003
    192
    Houston, TX
    \'72 12 bolt rebuild questions
    Has anyone gone ahead and bought a new high perf rear end complete? It is time to rebuild my backside and will cost around $900.00 to get it done. I think that I can get a Currie unit for around $1500.
    Has anyone else gone this route? It is a ton of $$$$, but may be worth it in the long run.
    Does anyone have any links re: DIY rear end rebuilds? If I can DIY, maybe I will do the front and Tcase as well.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Re: \'72 10 bolt rebuild questions
    72 would of had a 12 bolt from the factory.
  3. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    why do you want to rebuild a half ton rearend? like said before it should be a 12 bolt, it is a 10 bolt it was swapped in
    but like i said why would you want to rebuild a halfton rearend?
    if you want to stay with 6 lug rims, id seriously consider getting a 14bolt SF
  4. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Please donot keep that 10bolt under there. At leaset get a 12 bolt back to the way it should be. I have never owned a 10bolt but all that I have seen/read is that 10 bolts die all the time, built up or not they don't seam to be the best choice for a rear end. Kinda to bottom of the barrel for rear ends.
    .02c
  5. mastercraftkpk
    Mar 12, 2003
    192
    Houston, TX
    Re: \'72 12 bolt rebuild questions
    Thank you for all of your opinions re: 10 bolt vs 12 bolt. It was a typo....I have a 12 bolt.
    BACK TO MY MAIN QUESTIONS
    1. Has anyone gone high perf w/ a Currie or like complete rear end.
    2. Does anyone have any good links re: rebuilding rear ends?
  6. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
  7. Panther
    Panther 1/2 ton status
    Aug 31, 2000
    845
    South Jersey
    I've been debating the rear axle question myself for my 73. I've decided in the long term to go with a 14 bolt. I'm not trying to start another 12b vs 14b debate, but for about the half the price of building up my 12b, I can get a comparably equipped 14b. What I'm losing is 250lbs in lightness (in other words, the 14b is 250lbs heavier) and an inch in clearance once I shave it (2 inches stock).
    The real kicker was I wanted a FF axle and the FF kit for a 12b was more than I can get a 14b for with a locker.
