72 1ton pickup?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by backwood heavy, Nov 18, 2002.
  1. backwood heavy
    backwood heavy Registered Member
    Apr 3, 2002
    12
    Passaic cty, NJ
    In 1972 was there a 4X4 1 ton pickup model. And if there was, what kind of beef was built into them. And are we still talking drum brakes and manual steering? Here is waht the ad says and I think Ill call right now:
    <font color="red">1972 CHEVROLET 4WD 4-Wheel drive Pickup, 1 Ton, V-8, 4-speed, ps/pb, runs &amp; drives, to use or restore</font color>
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    No.
  3. backwood heavy
    Apr 3, 2002
    12
    Passaic cty, NJ
    Ok, the guys not home so its probably a 3/4 ton.
  4. bouncytruck
    bouncytruck 1/2 ton status
    Oct 11, 2001
    858
    Bothell, WA
  5. BigMac
    BigMac 1/2 ton status
    May 27, 2002
    397
    Fremont, CA
    They cam in 3/4 ton.
    The biggest difference is the big eaton rear. the 8 lug front dana 44.. bigger breaks, double diaphram break booster.
    Im sure there are a couple of other things that I haven't found different yet...
    Oh yeh... the double diaphram booster requires a shorter bracket than the 1/2 ton comes with...
    edited to add
    72 had front disk
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    check the title and registration papers, they will say 3/4 ton or C/K20 i bet, no 1 ton 4x4 til sometime after 72, at least from factory anyways
