72 3/4 4x4
Discussion in 'Parts & Trucks Wanted' started by gn4u2c, Feb 24, 2006.
  1. gn4u2c
    gn4u2c 1/2 ton status
    Oct 29, 2003
    287
    Pa 17329 zip
    looking for a locker for my stock 8 lug rear, I have a 14 bolt but do not want to swap in and lose the clearence. let me know what ya got. shipped to pa 17329 zip
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Use of the 14FF axle shafts in the Eaton rear end will let you use the 14FF Detroit locker. Unless your talking about a Dana 60 rear axle? Which axle do you have?
  3. gn4u2c
    Oct 29, 2003
    287
    Pa 17329 zip
    factory eaton
  4. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    I can get you a factory open eaton third (to weld) with 410s for 50 bucks plus shipping.
  5. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    I have a Dana 60 rear that will work in your truck. Same pad width. 4.10s open and I have posi for it. Going 6 lug and don't need it.
  6. kennyw
    Jun 9, 2002
    13,223
    94
    Buy a Detroit for a 14FF and use it in the stock Eaton Carrier. Use your axleshafts from the 14FF and your set. A lot stronger axleshaft splines in the process too.
  7. sweetk30
    Nov 1, 2004
    25,536
    533
    horseheads , ny 14845
    i have spare shafts if you dont want to brake up a good axle setup.
  8. gn4u2c
    Oct 29, 2003
    287
    Pa 17329 zip
    thanks for the advise the 14 has a factory locker in it so I guess I will just swap them in and hope it works out.
  9. kennyw
    Jun 9, 2002
    13,223
    94
    hold on... the what your calling the stock locker is a Gov-Loc unless it came from a CUCV. Not the same thing as a detroit... but you would want to research if it is a direct swap or not. The GovLock uses a different carrier than the open diff.
