72 3/4 ton rear axle
Discussion in 'The Garage' started by Cornfield creations, Oct 30, 2005.
  1. Cornfield creations
    Cornfield creations 1/2 ton status
    Oct 19, 2005
    1,283
    Jasper, Indiana
    Just out of curiosity, is the 72 and older 3/4 ton full floater rear axle a 12 bolt? I believe it is a third member axle. Can anyone verify this?
  2. sweetk30
    Nov 1, 2004
    25,536
    532
    horseheads , ny 14845
    dana 60 or eaton rear. eaton rear is third member style.
  3. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    The predessesor to the 14 bolt actually had 10 bolts w/ a drop out third member and a removable cover. It is a eaton style and refered to as the eaton rear or by RPO numbers, H052 and H072, with the only difference between the two being the brake size and the H072 having a thrust pad to prevent the ring gear from deflecting away from the pinion. Used detroit lockers (called no-spins) are the only traction aid available.
    The dana 60 only had 10 bolts on it's cover also.
