72 and 76 Interchange???
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by bryanrash, Feb 13, 2006.
  1. bryanrash
    bryanrash Registered Member
    Dec 7, 2003
    38
    I have a 72 and a 76 truck. Both are 4x4 half tons. Will the parts between the two be interchangeable? What about with a 72 K5?
  2. Scrubby
    Scrubby 1/2 ton status
    Dec 1, 2001
    114
    Boise, ID
    Some parts are. Some are not. For example, I have the Dana 44 front axle out of a 76 on my 72 K5.
  3. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    '69 - '72 are very interchangeable.....
    There are select things you can also use from later trucks:
    Engine/Transmission/Transfercase
    Axles
    Rear Springs
    Frames are completely different, front springs aren't the same length...body panels are obviously different. Seats might interchange with some extra work on mounts.
    The beauty of playing with Chevys is that a LOT of interchange exists between 1969 and 1991. That becomes important when you start looking for beefier axles, etc. It's pretty easy to find parts that will work.
    :usaflag:
  4. botboy
    botboy 1/2 ton status
    Aug 11, 2004
    225
    Delano, MN, USA
    Axles...fronts will interchange up till '80-something (87 IIRC, maybe later for the solid front axle trucks that didn't get the new body style until 92). 3/4 & 1 ton rears will "bolt in" but the axle tubes are bigger and will require wider U-bolts
    Rears, the 73+ 1-ton rear axles will interchange into the 67-72 1/2 tons/K5's as the leaf spring pads are the same width apart. 3/4 & 1/2 ton 73+ rears will need the spring pads moved in.
    I am in the process of swapping a set of axles from a '77 3/4T 4x4 underneath my '71 K5 Blazer, the front axle was an easy swap with a couple buddies, I just bolted the rear in with a piece of 2x4 on the axle tube so that I could roll it in the barn...too cold to work on it out here, when I pay my hosting bill I'll post up a bunch of pics of the swap progress.
