72 axels
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by nstarry, Feb 19, 2004.
  1. nstarry
    nstarry 1/2 ton status
    Feb 13, 2004
    349
    st.cloud minnesota
    I am putting a 3/4 ton running gear out of a 72 short bed chev
    into my 74 k5 next week this isint a direct bolt up right those spring purches in the 72 are wider write????? /forums/images/graemlins/confused.gif /forums/images/graemlins/thinking.gif
  2. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    you are correct. it's just the rear axel you have to worry about. also check on the shock mounts.
    ARQ.
  3. nstarry
    Feb 13, 2004
    349
    st.cloud minnesota
    how do you do this install properly?? /forums/images/graemlins/k5.gif
  4. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    The spring perches are different, and there is no such thing as a '72 3/4 ton short bed.
  5. nstarry
    Feb 13, 2004
    349
    st.cloud minnesota
    sorry maybe its a long , /forums/images/graemlins/doah.gif it doesent have a box it just looks short to me
  6. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    The fronts axle is a direct bolt in swap. The rear is not. The '72 axle has spring perch distance of 40" center to center. The '74 K5's perch distance is 42.5". You will need to cut the perches off and weld them on at the correct spacing. You will need to move the shock tabs as well. /forums/images/graemlins/waytogo.gif
  7. nstarry
    Feb 13, 2004
    349
    st.cloud minnesota
    Thanks man!! /forums/images/graemlins/grin.gif now all I need is a cuttin tourch & welder /forums/images/graemlins/angryfire.gif
  8. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    what axle is it, a 12 bolt or 14 bolt? /forums/images/graemlins/truck.gif
  9. Blazer1970
    1,600
    Old Mission, MI
    '72 3/4 ton would have and Eaton most likely or possibly a Dana 60.
  10. nstarry
    Feb 13, 2004
    349
    st.cloud minnesota
    EATON /forums/images/graemlins/rotfl.gifhe he he , the front is 44 I dont think its much stronger than the 44 I got in the the k5 now it just has that damn 8 lug patern to match the eaton
