72 blazer lift kit
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by chulisohombre, May 8, 2002.
  1. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    i just put a pro comp lift on my blazer.my rear axle now rests about 2 inches forward to the front of the wheel opening.why is this.can anyone help?
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Did you put the springs on the right sides? Front or rear?
    The factory springs AFAIK have the center pin in the center of the spring. When you get aftermarket springs they sometimes move the center pin to make it look right.
    The part # that is on the spring should be on the front side of the spring.
  3. chulisohombre
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    i thought i had them on right because of the way the weges were on the bottom of the spring.are they supposed to have the smaller side torward the front for pinion angles?when i took the lift blocks off the smaller side was to the front so i thought that was how to install the springs.i measured them it has 26 inches to the center pin torward the back and 25 to the front.would it be better to switch the direction of the srpings around?
  4. chulisohombre
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    by the way they were just the rear springs i replaced.the front was already done but are4 sagging a little so eventually those will get done too.
  5. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Sounds like you need to turn them around. You could also turn the degree shims to make the driveshaft angles work. Maybe they got put on wrong at the factory?
  6. chulisohombre
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    sounds about right.thanx for the help.
  7. chulisohombre
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    sounds about right.thanx for the help.i'll try that and see what happens
