72' blazer lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wfahlgren, Dec 31, 2000.
  1. wfahlgren
    wfahlgren 1/2 ton status
    Dec 30, 2000
    157
    Northern California
    72\' blazer lift
    I have a 72' blazer. It's stock with 31's I want to put 35's on it what lift and size rims should I put on it. Also what kind of little things might i run into installing it my self. What other helpful hints might I do to make it work better.
  2. smp
    smp 1/2 ton status
    Jul 5, 2000
    708
    Florida
    Re: 72\' blazer lift
    I run a 6" front and a 8" rear lift on my 72 and it will clear 35's perfect and the biggest problem that i had was the 28 year old rusty bolts for the leaf springs i had to use an air hammer to get them out and then replace those bolts but other than that it wasn't too bad.
    <A target="_blank" HREF=http://WWW.SMP.COLORADOK5.COM>http://WWW.SMP.COLORADOK5.COM</A>
  3. TheBlazerKid
    TheBlazerKid 1/2 ton status
    Apr 26, 2000
    259
    Raymond, Washington
    I'm going to go to 36' soon on my 71 and 6" all around should be plenty, did you remove leaves on your 8" or what smp???
    Theres No Replacement for Cubic Inches!
  4. 1HIHUM
    1HIHUM 1/2 ton status
    Jun 28, 2000
    366
    Fremont, CA
    six inches is fine for 35 or even 36 inch tires. You'll want to get some longer brake line, and possibly lower the transfer case. I used to have a six inch on mine with the hard brake lines bent to lower them(previous owner did that), but no other mods were done. I didn't have any problems other than a little vibration at freeway speeds.
    [image]http://albums.photopoint.com/j/View?u=1328774&a=9975627&p=33244094[/image]
  5. smp
    smp 1/2 ton status
    Jul 5, 2000
    708
    Florida
    I went with the 8" in the rear to compensate(sp?) for the sag in the rear it sits about an inch high but you can't really tell you can see some pics on my web page.
    I am starting a early blazer pics page so e-mail me some photos and i will put them up on my site and some stats
