72 Dana 44 axles vs 73 up
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Rusty68, Jan 24, 2003.
  1. Rusty68
    Rusty68 1/2 ton status
    Jan 22, 2003
    116
    Elko, Nevada
    What are the differences between the 72 down disc front end and the 73 up? I noticed that the hubs are bolt on rather then the inner mounted style. Someone told me the 72 down have weaker shafts. So what is the deal? I have a 71 and a 76 front to choose from. Inform me all wise chevy gods....
  2. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    if the hubs are the bolt on iam assuming 3/8 bolts and they are spicers. these are not made any more and cant be fixed. something to think about. they do have weaker u joints on the earlier. if you plan on crossover sterring you need the flat top knuckles (71). but i think it all can swap between the 2 axels, might have to change bearings for the better shafts. this is IIRC though. do a search triaged has explained this many times. several to me.
    nathan
  3. IGOR
    IGOR 1/2 ton status Premium Member
    May 16, 2000
    2,303
    19
    Damascus, OR
    These will be the same axles -
    In 77 it split to heavier Dana 44s - didn't I give you the Dana 44 conversion link the other day? /forums/images/graemlins/confused.gif /forums/images/graemlins/grin.gif
    I'm looking for the bearing hubs for a 73-76 3/4 ton front axle if you want to make some $$
  4. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    '72 down has the smaller ujoints. If they haven't been changed allready. The big bolt on hubs on the 3/4 tons cross over to ford hubs too. Check the '76 to see if the right side is a flat top knuckle too.
  5. Rusty68
    Jan 22, 2003
    116
    Elko, Nevada
    Ok, here is what I have been faced with. I know a guy that will trade me my 76 Dana 3/4 ton front for a complete 71 front axle and rear 12 bolt. I had asked about the 44 to 10 bolt parts interchange, but I did not see any info in there about the early style fronts. Maybe I need to re-read it. so I will for go the questions I now have until that time. Besides you gotta cut me some slack. I am new:)
  6. Rusty68
    Jan 22, 2003
    116
    Elko, Nevada
    Ok, so from my search I gathered that the later style axle shafts will slide in place of the early style enabling you to ditch the weaker/smaller ujoints. And since that is possible, then you no doubt could use a later internal hub in the event you blow one of the unreplaceable external type. I think I just melted my brain.....
  7. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    good work...keep looking as I have the same problem /forums/images/graemlins/k5.gif
  8. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    Theres plenty of the early style hubs out there. You just have to look at jeep/ ford/ dodge trucks to find them. The other companys kept running external style hubs after chevy switched to internal hubs.
  9. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    if youi replace the outer locking hub assembly with internal hubs you should be alright.all dana 44 shafts are interchaneable.the pre73 were weaker and a cheap upgrade is to change to post 73 shafts and ujoints.in my opinion the warn hubs run the best and i think they hae some kind of warantee.ive gotten a couple of parts for free from them.
  10. Rusty68
    Jan 22, 2003
    116
    Elko, Nevada
    I picked up a D44 today with all good parts except the pinion bearing is shot. So I will use it for my outer swap. It even has warn hubs! A bonus for $35.00
  11. chulisohombre
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    the hubs locks alone are 80 bucks so you got a great deal.
  12. IGOR
    May 16, 2000
    2,303
    19
    Damascus, OR
    Sweet - that's an awesome find!
