72 dana 44 bleeder screws for 83 10 bolt calipers ?
Discussion in 'The Garage' started by R72K5, Nov 23, 2003.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    does anyone know if 72 blazer dana 44 bleeder screws would work in 83 10 bolt calipers ?
    need to know, i have a pair of 72 blazer calipers with good screws and i need them for the 83 k20, if they will work ?
    thanks
  2. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    NO !! They are very close but they are metric vesus standard. I believe 7/16 vs 8mm ? Or something...those numbers could be wrong but i know those are different threads.
    Blake
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    that stinks,
    i noticed that one of the dana44 ones are 10mm and other wasnt, and i dunno what the 10 bolt ones are, i didn read the socket, just tried a bunch til one fit
    hmm,..
    thanks
  4. 88jimmy4x4
    88jimmy4x4 1/2 ton status
    Oct 19, 2003
    947
    3
    Houston, Texas
    My 88 Jimmy has 10 bolts and they are 10mm.
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    hmmm...
  6. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    Ummm writing this question post prolly took longer than it would to actually try them. Just go out... unscrew the one, try the other in it. If it fits, rock on. If it doesnt, put the other one in. Why do you need to change them? Not much can go wrong with them other than stripping the socket end. If they arent stripped, just take a small piece of wire and clean them out, spray some WD40 thru it.
    Mike
