72 diesel convertion ?
Discussion in '1982-Present GM Diesel' started by earl87gta, Aug 5, 2005.
  1. earl87gta
    earl87gta 1/2 ton status
    Apr 6, 2003
    551
    Chuckey TN
    Ive looked and I cant find it will the 6.5 bolt in to my 72 K5 using the SBC engine mounts or do I need to change to the big block mounts?
  2. Robert79K5
    Robert79K5 1/2 ton status
    Mar 23, 2003
    335
    Douglasville Georgia
    I put a 6.2 in place of a 350 in my 79 with the same mounts. I know your 72 is a different generation than mine but theres no reason that the diesel wont at least bolt up to the small block motor mounts and transmission. I can't tell you if there will be issues anywhere else though.
    Good luck mang.
  3. rd durham
    rd durham Registered Member
    May 20, 2004
    70
    Colorado Springs, Colorado
    I just dropped in a 6.2 into my '79 Jimmy. Jimmy previously had a 350 SBC and the install was a straight drop in for the engine.
  4. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Yep should be a direct swap
  5. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    As far as I know the Mounts are the same but the clearance is not.
    You will need the tower for the mounts from a BBC or the crossmember from a 2nd gen to clear the pan and the exhaust manifolds.
    It's the same dimensions as a BBC so what a BBC needs to fit, it needs it too.
    IceMan
  6. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    Just FYI, the distance between the mount holes for both 6.2's and BBC's is exactly 16.5" I don't know about the depth but I had to build a custom engine crossmember for my truck so I have all the measurements.
  7. earl87gta
    Apr 6, 2003
    551
    Chuckey TN
    Thanks Guys I may end up using the cross member from the k30 or building a new one. Its hard to find the big block parts for these trucks and when you do thier not cheap. I was hoping I could judt bolt it in with no trouble. I need to find a 6.2 engine block that is scrap so I can use it to set every thing up. Im going to drive the k30 this winter and swap the engines in the fall. By then the chassis chould be don getting reworked and the body back on.
  8. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    Well....yes and no.
    The 6.2L is slightly larger than the small blocks, but not quite as large as big blocks. They share the same motor mounts and bellhousing configurations as both, but that's about it. The 6.2L is a bit wider and longer than a 350, but yet smaller than a 454. It's in its own class.
    Casey
  9. earl87gta
    Apr 6, 2003
    551
    Chuckey TN
    I was hoping I could get luckey and just take the 350 out and drop the 6.5 in with out having to change the mounts and use whts already thier.
  10. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    so if i pull out a 6.2, then i can put a 400 in with the same motor mounts?
    on a 83 K10
  11. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Blasphemy!!!!
    But yes technically you could, but why would you?
  12. Robert79K5
    Mar 23, 2003
    335
    Thats what im sayin! :crazy:
  13. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    From all the guys ive talked to my 6.2 is to heavy and doesnt turn enough RPMs for mud and I have a 400 at my disposial. Im sick on not being able to drive it in the cold iowa winters to work because its such a cold blooded SOB.
  14. Robert79K5
    Mar 23, 2003
    335
    Were just having a little fun don't worry.
    Ill be the first one to tell you to evaluate your specific use and then choose whichever works best.
    If I was strictly a mudder I would probably still have a gas engine in my Blazer.
    Why do you say your 6.2 is cold blooded? You may have something wrong thats easily fixable such as bad glo plugs.
    After putting in some quality dual coil glo plugs in my 6.2 it starts quicker than my carburated 350.
  15. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    its not just that its a hard starter when it is cold out. bad harmonic balancer, flexplate is fubared, uses, leaks and sprays oil. Its ran hot ever since ive own it too... Its simply not reliable anymore. I love the 6.2 though, that is why I am keeping the C10 that I have a 6.2 its great motor. But ya, most all I do is mudding. Anyone who has seen my pathetic flex pics knows Iowa is flat :crazy:
