72 DOOR FRAME QUESTION
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by KYRO72, Apr 19, 2002.
  1. KYRO72
    KYRO72 Registered Member
    Jan 19, 2002
    7
    New Orleans, LA
    CAN ANYONE TELL ME IF THE 72 BLAZER HAD THE FRAME AROUND THE TOP OF THE WINDOW ON THE DOORS. I JUST INSTALLED A SOFT TOP & IT DOESNT SEAL UP AROUND THE WINDOWS AT ALL.....
  2. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    No, it did not. No Blazer had a window frame on the door until 1976. What kind of soft top did you install? My Kayline does not seal perfectly around the side windows, but it is good enough to keep most of the weather out. It helps if your window tracks in the door are in good shape. The window tracks can also be adjusted to change the angle of the back of the window.
  3. WD Steeves
    WD Steeves Registered Member
    Nov 9, 2001
    16
    B.C.CANADA
    The Blazer door window glass weather stripping is mounted in the canopy.Blazer doors do not have a frame for the glass.The doors are pickup doors and they give you instructions where to cut the frame off for Blazers / Jimmy's.That is the way mine were from a GM dealer.
