72 Jimmy Build up HELP!!
Discussion in 'The Garage' started by 72jimmycst, Oct 27, 2005.
  1. 72jimmycst
    72jimmycst Registered Member
    Sep 5, 2005
    17
    Rapid City SD
    I've come across a 76 3/4 chevy p/u the front axles are marked "44HD" on the top left of punkin. Is there such a thing as a heavy duty 44? Is the rear a D60? How hard would it be to swap these into a 72 Jimmy 1/2 ton with a built sb 400 and stock TH350, what are the pro/cons. I'd like to run 35" with lockers and a Doubler next spring. Any ideas on which locker. Been fixing broken CK's for years and beside a 2" lift on a 72 burb i don't have much of an idea what's best, so any help I can get will help alot. Thanks
    P.S. Any thoughts on a TH350 to 700R swap? :confused:
  2. 72jimmycst
    Sep 5, 2005
    17
    Rapid City SD
    One thing I forgot I'm uesing a np 205 if that helps. Thanks again
  3. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    A 44 is a 44 with the exception that in 3/4 ton trucks they came with 8 lug outers..(6 lug on 1/2 ton) It could have a Dana 60 rear but that would have been swapped in and not from the factory ..So it more then likely has a 14 bolt (again if it is 8 lug for a full floater or 6 lug with a 14 bolt semi floater)if it is really a 3/4 truck (you didnt say if it was a short bed or long bed truck..)
    If the d44 is 6 lug more then not the rearend is a 12 bolt..
    Not a upgrade from what should be under your rig now..44/12 bolt.. :crazy:
  4. 72jimmycst
    Sep 5, 2005
    17
    Rapid City SD
    8 lugs, long box and door vin plate all say it's a 3/4 ton
  5. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    A '76 3/4 ton would have a D44/14BFF combo. The D44 is no stronger than what you have now other than the thicker axle tubes and larger axle u-joints.
    My '71 D44 had 2.75" dia tubes and the '77 D44 I swapped in has 3" tubes. I would assume that your '72 D44 would be like my '71.
    The 14BFF will require some mods to get it under your Jimmy. 1967-72 GM 4X4's have a rear spring perch width of 40" center to center compared to the 73-up 1/2-3/4 ton spacing of 42.5" You will need to move the perches to 40" apart and relocate the shock tabs.
    The swap is pretty easy once those hurdles are crossed. :D
  6. 72jimmycst
    Sep 5, 2005
    17
    Rapid City SD
    So I'll just drive it till it's broke. Thanks for the input
  7. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    An HD D44 has external hubs and the axle tube thickness is 1/2".
    Other than that is is just like any other D44.
